Hi all,
We have an 8000 gallon pool using a SWG to produce chlorine. The pool water is in total balance.
The issue I'm having is even with the chlorinator set at 20% and the pump running 7 hours, I'm getting a surplus it chlorine each day with no drop overnight.
I know this is an issue many on here wish they had since most of the posts involve algae and chlorine demand.
Since this is an issue of adjusting pool pump timer, how low can you get in hours before the pool water isn't getting a full turnover and starts getting cloudy from not filtering?
Test Results 11-09-2018 @ 06:49 PM
Free Chlorine: 8.5
Combined Chlorine: 0.0
CSI: -0.42
Test Results 11-08-2018 @ 04:44 PM
Free Chlorine: 7.0
Combined Chlorine: 0.5
pH: 7.5
CSI: -0.42
Chemical Addition 11-08-2018 @ 01:11 PM
+ 13 FluidOunces of Baume31
+ 55 FluidOunces of LiquidStabilizer
Test Results 11-08-2018 @ 12:31 PM
Free Chlorine: 7.5
pH: 7.8
Total Alkalinity: 60
Calcium Hardness: 400
CYA: 50
Salt: 3800
Temperature: 76°F
CSI: -0.13
Maintenance 11-08-2018 @ 11:37 AM
Vacuumed, Cleaned Filter, Brushed
Test Results 11-08-2018 @ 08:01 AM
Free Chlorine: 6.5
pH: 7.8
CSI: -0.03
Test Results 11-07-2018 @ 10:18 AM
Free Chlorine: 9.0
CSI: -0.32
Test Results 11-05-2018 @ 10:25 AM
Free Chlorine: 9.0
CSI: -0.32
Test Results 11-03-2018 @ 05:13 PM
pH: 7.5
CSI: -0.32
Chemical Addition 11-03-2018 @ 03:04 PM
+ 18 FluidOunces of Baume31
Test Results 11-03-2018 @ 02:39 PM
Free Chlorine: 11.0
pH: 8.0
Total Alkalinity: 80
CYA: 60
Salt: 4000
Temperature: 72°F
CSI: 0.16
Jandy Ei 35 SWG, 8000 GAL, Jandy PHPM .75 pump, cartridge filter, Central Florida
Free Chlorine: 8.5
CSI: -0.42
Free Chlorine: 7.0
pH: 7.5
CSI: -0.42
Free Chlorine: 7.5
pH: 7.8
CYA: 50
Salt: 3800
Temperature: 76°F
CSI: -0.13
Free Chlorine: 6.5
pH: 7.8
CSI: -0.03
Free Chlorine: 9.0
CSI: -0.32
Free Chlorine: 9.0
CSI: -0.32
pH: 7.5
CSI: -0.32
Free Chlorine: 11.0
pH: 8.0
CYA: 60
Salt: 4000
Temperature: 72°F
CSI: 0.16
