Hello,
First time poster here so I apologize if this isn’t a reasonable way to start.
In the spring of the year we purchased a home with an IG plaster pool and elevated spill over spa. This is my first pool so to say I was a newbie in all of this was an understatement. After numerous let downs and what felt like extortions from the local pool companies I eventually decided to do all of the upkeep and work myself. This forum has been an invaluable resource to giving me peace of mind with the balancing and overall upkeep. By the end of summer things were very working very well and quite predicable.
I had hoped to get a company to assist me with closing but as they have all summer the effort has only resulted in more letdowns. While the overall condition of the pool was fairly good the upkeep and maintenance of the cover, pumps, electrics and plumbing maintenance and upkeep left me with a lot to do this first year. I think I have at least sorted out most of what needs to be done in the future and have repaired the cover and repaired the plumping/pumps enough to safely close for the year (although I am way behind where I wanted to be.)
I have a plan for closing and have gotten all of the plugs, cyclone (purchased and on the way), gizmo and can get the antifreeze I may need. Shooting for midweek this week for the big day. While I still have a lot of uncertainties but I think I have a procedure that will get me safely closed.
The question I have is in regards to the elevated spa. It is a spillover and has 6 or so jets, air blower and two drains. The returns/jets are run off of the main pump (at this time) with spa flow controlled by a jandy diverter valve on the main return. I think there is a second pump that I think served the jets that appears to be plumbed separately (but that pump was broken/seized and I haven’t been able to troubleshoot that as of yet so not really sure what it does)
For closing I have a few questions on the spa, with it being so shallow should I drain it entirely? I assume I should just blow out and antifreeze to the jets and then plug them. If I leave water in the spa below the jets should I airlock the drains or perhaps just reach in and plug them? I am outside Philly for reference..
I have a few pics but nothing that shows the inside of the spa at the moment that I can post if need be. Here is a picture showing the spa from the other side of the pool, the fence to the right is where the pumps/equipment are located.
BTW, Thanks in advance and many many thanks to all of those who post and help. This forum is the ONLY way I was able to make it through this first year and not go absolutely insane in the process.
