Ok - I don’t understand my plumbing in a pool i didn’t design and I wasn’t here when it was built.
I need to understand it better.
Its a bent L shape, with two skimmers. It has a main drain and there are five outlets.
A couple problems:
I can never get the bottom of the deep clean.
If I open the valve for the main drain, it inevitably kills my prime.
I drained the pool so I could deal with the Bottom and there was about two inches of mud and the drain was fully clogged.
I cleared it all and pulled the drain cover and unclogged it all. I noticed that there are two holes in the main drain, one from a pvc line that sits at a right angle from the drain collection area itself.
There is a second hole that is in the bottom of the collection area, but it has a plug in it.
Can someone explain to me what I am seeing, whether I ought to pull that plug out, and why i can’t hold prime with the drain valve all the way open.
Idiot alert - I dont know very much at all about what I am dealing with.
I am very appreciative of TFP and consult the board often. I can’t find another thread on this or I would not bother anyone —
Gary Young
Lincoln, Nebraska
30000 gal in ground
Hayward Aqua Rite SWG
Starite Sys 3 37sq ft DE filter
Hayward SuperPump 10ft lift
vinyl liner
and lots of trees
A couple problems:
Gary Young
Lincoln, Nebraska
30000 gal in ground
vinyl liner
and lots of trees
