Having some trouble with my spa jets. I have 2 pentair vs pumps, one pump runs water thru the filter and heater and controls 4 spa jets while the other pump handles only 8 spa jets (this pump is run only at one speed thru the Intellicom II). Both lines are hooked up to the same 2 hp blower. The trouble I'm having is that when I turn the spa on it seems to have low flow out of the jets on all 12 jets. Once I turn the blower on for a few seconds and then back off the jets are much more like you would expect from 2500 rpm 3hp pump.
Any thoughts on why I would need to turn the blower on for a few seconds to allow the pumps to power the jets properly?
Also, last night it seemed to happen while using the spa. After an hour or so the jets got weak even though both pumps were running at 2500 rpm. Was fixed by turning on and off the blower.
