Hi folks...
I am curious about the water loss in my pool. I never pondered it much because the auto pool leveler took care of it (out of sight, out of mind).
A few weeks ago, I shut the leveler valve off and decided to use my house soft water for evap compensation, because I am sick and tired of chasing that pesky Calcium Hardness. Our city water is 200ppm and my soft water is 25ppm.
Now I am using a hose (from the soft water bib in the back) to compensate for evaporation and I am a little concerned (possible leak somewhere?).
I know there are some folks on here that are "smarter than the average bear" when it comes to such things. So here is the information that might be required to help determine if I should be concerned with my water loss.
In 24 hours, the pool level dropped 5/16 of an inch.
The total area of the pool and spa is 678 square feet (36 x 18) and polygon spa with a radius of 3.1 feet .
It took 120 gallons to bring the level back to the original mark I made in the skimmer (24 - 5 gallon buckets).
The temperature in the Phoenix metro area is still a high of just over 100 degrees. No excessive wind in the last 24 hours.
Can anyone tell me if this seems like a normal evaporation rate given our prevailing high temperature and the surface area of my pool and spa?
Thanks very much...
r.
Thanks very much...
r.
