I changed my pool light to a multicolored LED bulb
LAMPAOUS LED Pool Lights Bulb, RGB Muliti Color LED Swimming Pool Lights, E26 Base Par56 Under Water Lights Replacement Bulb 120VAC 35 Watt
After I changed it, it worked great for about a week. Then, the gfci would trip as soon as I turned on the switch. I had the gfci replaced, hoping that would take care of the problem. That did not help, so then I checked the light fixture and noticed water in the fixture. So, I emptied it, let it dry out for over 24 hours, replaced the gasket, and put it back together. Now, when I flip on the switch, it comes on very faintly and dim. It's nowhere near as bright as it should be.
I should also note that it's wired to a 30A circuit shared with my water heater. The old gfci I took out was a 20A and the new one the elec. installed is a 15A.
Any help is greatly appreciated. Thanks is advance.
Pool is 22k, IG gunite.
