Bought house in January with 20 year old IG 20 by 40 rectangular pool. Had been closed for 6 - 8 years and was a swamp when we opened it (mud, snails, tadpoles, swamp grass, opaque green color). Fun!!
Pool clean now, want to replace sand filter which appears to be original equipment. Pinhole leaks in housing that pump bolts to, multiport valve leaks, and so on.
Reading about Sand vs DE vs Cartridge, I get the impression that a sand filter is inadequate in that it won't filter out algae, which seems to be the most common contaminant.
DE will remove algae (down to approx. 5 microns or smaller).
Cartridge will remove the algae and anything else that gets in because it filters down to bacteria size.
I am leaning toward a DE filter (easier to clean than Cartridge, IMO) combined with a robotic pool cleaner.
Any better suggestions?
Thank you!
Thank you!
