Hi TFP,
I have a dedicated VS pump for a raised negative edge spill over. I recently noticed that the water is no longer spilling over the entire wall causing dry spots when the pump is on low speed. I did recently clean the filter and change from de to aqua perl (de alternative). Filter psi is 18 (also the clean psi). I think the spill edge pump bypasses the filter and goes to the pool??? Hope I am making sense with this one.
Thanks for helping out!
