Thread: What are these particles floating in the water?
    Vero Beach, FL
    462
    I've noticed these white translucent particles floating in the water the other night when I had the lights on. They are flat and 2 to 3 millimeters square or rectangular. I can't detect them during the day - only at night just in front of the lights. I noticed it the most after brushing the pool as I probably stirred them up. I can capture them with a net and they are soft and fall apart when touched. I'm guessing its calcium, but my CSI has never ventured out of range (-.6 to .6) and is almost always around -.3. All numbers are in range for a SWG plaster pool. Any ideas? I'll try to get a photo.
    25' x 13' Roman, 12000 gal IGP, Plaster, with 500 gal Spa
    SWG, 1 HP Max Flo Pump, C-900 cartridge filter
    Solar heat
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Re: What are these particles floating in the water?
    They may be bits of scale from the blades of your SWG.
    Guest
    That is calcium that is in suspension.
    Bruce
    Vero Beach, FL
    462
    So is it anything to worry about? The SWG cell has been operating less than a month. It is self cleaning, is in a clear tube and I can't see any build up on it. Possibly it builds up and then flakes off.
    Solar heat
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Quote Originally Posted by lborne
    I think the previous posts are educated guesses. If it persists you could try to retrieve some of the flakes and have them analyzed...
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
