I just installed an IntellipH system into an existing Pentair setup including an Easytouch 8 automation system and Intellichlor IC40 on a pool/spa combo with Intelliflo pump. The first issue is that the IntellipH has a status light of red meaning it won't dispense any acid even with the system up and running. I am able to manually override and get the acid pump to dispense acid. The IC40 is working with all lights green and it is set through Easytouch to 25% for pool and 1% for the spa. The one thing that sticks out is that on the Easytouch it reads salt at 3600 along with pool temperature 85. The IntellipH screen reads salt 3600 along with temperature of --. I am pretty sure the Easytouch is reading the temperature probe that is mounted into the 2 inch pipe. I am guessing that the IntellipH is trying to get a temperature from the IC40. After several calls to Pentair technical support (no one seemed to know much about the IntellipH) I understand that their is a combined flow, salt and temperature probe in the so called "flow switch" on the IC40. They think that the temperature probe on the IC40 may have gone bad with the flow and salt part of the switch still working. Someone must have the answer?? Additionally, when I filled the IntellipH Acid container I discovered a round red plastic threaded rod shaped item floating (approximately 1 inch long and 1/2 inch in diameter) - one Pentair tech guessed it might be a filter that attaches to the end of the siphon tube and another said there was not anything on the end of the tube? It will be almost impossible to get it out of the container.
