Hello,
Unfortunately this Summer has been a summer without the enjoyment of our pool, for a couple of reasons. One of the reasons is our flag stone coping we had re-done a couple of years ago was loose.
I had to remove a section about 1/3 of the pool that was loose. There is another section that is not loose but lifts a little, it is not a safety issue and I don't want to turn this into any larger of a project so I will wait until next season.
This is the first time I have done anything like this so I am a little lost. I have done some reading on TFP which is helpful, but I still have some questions.
It appears there are different layers of mortar. There was a top layer which I removed and then there is a solid base of mortar. On 1/2 of the section I am working on I have removed all mortar, on the other 1/2 it still remains. The pool wall / beam is in good shape, no cracks or anything.
There is a 3-4" space that separates the pool wall from the cement deck. This has / had mortar there. I removed any hollow sounding mortar which was most of it. I identified some delaminated pebbletech that was removed.
1. Do I need to remove the solid mortar? It is very solid sounding (first picture)
2. How do proceed to build this up where I removed all mortar?
3. Should I use cement in the gap (vs Mortar) between the cement deck and the pool wall?
4. How to build up the wall in the front where the pebble tech was delaminated, Hydraluic Cement?
5. So water does not continue to erode the mortar What should I use to seal the crack between the existing flagstone and pool?
Pictures
1. First layer mortar
2. Gunite / Second layer Mortar
3. Gunite / Second layer mortar closer
4. Gunite - done removing mortar. also shows gap between pool wall and deck
5. Delaminated Pebbletech
Thank you
Pictures
Thank you
