- Mar 28, 2007
- 276
- Plaster
- Pentair Intellichlor IC-40
I've got two pool lights. If I recall, the lights are made by Pentair. They are 500W, 120 VAC and installed in Hayward niches. The pool was built about 3 years ago.
A couple of weeks ago, I was cleaning my pool and noticed a horizontal line across each of the lights. At first, I thought it was some type of shadow, but they persist even when I turn the lights on. The lines are below the midway point of each light, but it's hard to tell. The water has been too cold to swim in, so I have only seen the lights from above the pool water level. It is possible that they have been there all along and I just now noticed them.
It looks like there is water inside the light. Am I mistaken? I know that the niches are supposed to be submersed, but I thought that the interior was sealed against moisture. As of now, the lights still work fine, although we rarely use them.
I'm concerned that the water may reach the level of the electrical socket and cause a short circuit. I know that there is a GFCI breaker, but is there still a shock hazard? If there is a danger, I will switch the breaker OFF, so that the lights cannot be turned on by my control system.
