I am converting an 11000 gallon in ground pool that has had Baquacil in it for most of its ~20 year life. We purchased this home in April and have had issues with water cloudiness, white water mold, and stubborn algae that the Baquacil products won’t take care of. I attempted to keep the pool open for this season with the Baquacil but I have spent around $200 on sanitizer, algistats, flocculant, line clean, and filter cleaner. My sand filter most likely has a cracked lateral or maybe channeling (I get sand in the returns after backwashing even if I run the filter on rinse afterward) but I don’t want to change the sand before we start the conversion process.
I got my Taylor test kit, did all the tests, used the Pool Math calculator, and per the Pool Math calculations I just dumped 343 oz of 6% bleach into my pool. My water changed colors, and now my pool is filled with white foam. I just retested the chlorine after maybe 20 minutes had passed, and my FC is at 2 and my TC is at 5. I need to get the FC to 15.
So now do I just keep adding bleach and re testing until I get the FC up to 15? Is the reason the Pool math calculation’s prescribed amount of bleach to get the pool up to 15 didn’t work because the biguanides are consuming it? I just want to make sure I am on the right track!
