I'm wondering if the sand filter ( and/ or it's laterals) are going bad.
Approaching the pool once a week, the water appears to be clear. The water is balanced.
However, when i drop the vac head on the bottom of the pool. What appears to be like 'baby powder' like consistency wisping up when disturbed.
The pool never had algae issues or any problems like that. However, the pool is a big aged.
When I start vacuuming, it's like watching a dune buggy driving across the Mojave Desert!.
Then, I'd look slightly over to one of the pool returns (while vacuuming), and the pool return, the stream looks like a fire extinguisher going off!
Then, some time later, I can no longer see the bottom ( like a white out).
The thing is, i do other pools with the same water balance. The same amount of hTh shock, but they don't suffer the same problem.
Has anyone had this experience before where the filter ( or sand etc) was to blame??
Thx
BTW, the Alkalinity & Hardness are low ( around 60 for alk and 250 for calcium chloride )
Thx
