Thread: SWG Question
    SWG Question
    If my SWG states that it produce 300ml or 10oz of Chlorine per hour and I run my pump 6 hours a day. How many oz of 6% bleach = 60oz of Chlorine my SWG produce????
    25,000gal Inground Plaster Pool
    Pentair WhisperFlo WFE-6 1.5HP X 3
    Pentair Clear and Clear Plus Cartridge 420
    Pentair MasterTemp 300,000 btu Heater
    Compu-Chlor Super Salt System
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Re: SWG Question
    Quote Originally Posted by kmtyb
    Hello kmtyb,
    What brand/model of SWG do you have? Off hand, the SWG output doesn't sound right. I believe that my SWG can produce up to 1.45 lbs chlorine per 24 hrs -- that would be just under 1 oz. per hour. There's a rather technical discussion on this forum on this topic. See Chlorine output from SWG. Perhaps someone else here can condense this into a useful formula of xxx oz chlorine = addtional xxx ppm per so many gallons of water.
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    Re: SWG Question
    I have a Compu Chlor SWG with Auto 300 Cell.
    http://www.compupool.com.au/product/gen ... _auto.html
    The unit came with the house that I purchase few month back and I'm trying to figure out little more details on this unit.
    Jul 2007
    Brisbane, Australia
    874
    Re: SWG Question
    that would probably be a 30ml(g) per hour
    300ml/hour is a commercial unit, and Compuchlor doesn't make those
    chlorinators produce 100% chlorine, so to convert it to bleach you would need to multiply by 100 and divide by bleach concentration
    so 30g/hour is the same as 0.5L of 6% bleach /hour
    maybe they rate their cells in 10% bleach, hence 300ml in their specs
