I have a small pool which is built into a deck and is kinda half-inground. It's rectangular, has hard walls of galvanized steel, and partially in the ground and partially above ground. The size is 18' x 8' and that makes it about 4500 gallons.
I'm re-piping it and going to use 1.5" flex PVC pipe which will all be above ground (but below the deck). I don't see any reason to go to 2", is there? The old pump is 1.5HP and I'll probably get a variable flow pump of the same HP, though it seems too much for such a small pool. I'll also put in a salt water generator.
By the way, choosing between Hayward and Pentair, Pentair does minimal warranty of DIY work (60 days, I think) and for that reason I was inclined towards Hayward. But I was also told that recently the quality of Hayward went way down and that makes me a bit worried about that. Any comments on that.
I'm attaching a couple of sketches of what I plan to do (UBV is union ball valve, SWG is salt water generator). Am I doing anything wrong?
and
and
