I have been slamming for over 2 weeks --- I have bought the correct FAS-DPD KITS.
Last Thursday I had a CYA of 80 ---- i tested last night and my CYA was around 50 ppm
This morning my FC was 15ppm - my PH was over 8ppm -- I did the Overnight FC Loss test (OCLT) -- it was both 15ppm last night when I tested and this morning. So, Zero Loss.
But My Water is still cloudy, at the shallow end 3 1/2 feet, I can see ONLY as far as my 2nd step, I can't see my 3rd step or the bottom of my pool. I have been slamming for a while now, and I don't see noticeable improvement in the cloudiness.
Questions:
1) After slamming, what does the FC need to go down to - to be able to accurately test PH ?
2) Is it normal / common to pass the Overnight FC Loss test (OCLT) before the water stops being cloudy ? - does passing the Overnight FC Loss test (OCLT) happen before water returning to crystal clear ??
3) I"m at a loss at what to do.... I'm thinking to try Leslie's ClearAid ....
Thanks in advance..
Questions:
Thanks in advance..
