I'm a first time home and pool owner as of about a month ago. Thanks to TFP I've learned the art of pool chemistry, but now I'm looking for some assistance with a small leak.
Here is a picture of where you can see a little water dripping out: https://i.imgur.com/Pc1uew8.jpg
It's not too bad, maybe about 1 drip every 2 or 3 seconds. This weekend's project for me was to learn how to open up and hose down / clean out the filter — if it wasn't for that I probably wouldn't have even noticed it. If I feel around the joint in the PVC pipe I can feel where (I think) the water is escaping from. I'm just not sure what adhesive I should be using for this project. I've done some Googling but it seems like a lot of the adhesives used go where you connect the joints and not around the joints themselves after this pieces have been put together.
if it helps at all, here is a picture of the entire setup:
https://i.imgur.com/rZoyk3Y.jpg
Thank you
Thank you
