Thanks in advanced, lots of questions below really appreciate the value of this community(so far been lurking). I've linked to images to hopefully help with some of my questions.
We purchased the home which came with the pool. We are new to caring for a pool but are eager to learn and have been updating it as we can!
We replaced the old equipment when we moved in. We replaced a pool pump and a spa pump with one Intelliflo VST pump and replumbed with valves to enable the spa and pool to use the same pump.
One problem we have is that the spa does not really have any sort of bubbles just any that are a consequence of the water being sent into the spa.
One tech suggested that the jet covers on the spa were too wide, they are recessed into the concrete and he wasn't able to remove them at the time.
However another installation tech said that was not true and showed a pipe that could be used to add a blower. We tested this by using the "blow" feature on a shopvac attached to the pipe and the bubbles in the spa are what you would expect. He explained that water can sit in the pipe and block the air from getting in to the spa line.
Ideally I would not have to use a shop vac to blow my spa
When it comes to choosing a wattage and HP for the blower what should I consider?
I have noticed both 240v and 120v I would like something that is quiet and energy efficient(Image of our pool subpanel, which is fed by 80amp/220v from the main)
The spa has 6 jets in the spa. When the pipes are set to suck from the spa and return to the spa it appears that only 4/6 of the jets actually propel water.
The spa is located about 20 feet from the Intelliflo pump(Image of layout) and they are on the same level more or less.
If we were to add a blower would this allow us to run the pump at lower RPMs as well? Right now we are running the Intelliflo around 3450 RPMs when using the spa and it's a bit noisy.
The pipe I would connect the shop vac and blow is 1 1/2" . There is another 1 1/2" pipe that was capped off, could this be the mystery of the 4/6 jets working in the spa?
There is also a random seized valve that is near the spa, any idea what this could be used for? One tech said maybe for air? How would I unseize/replace the valve, I tried WD-40-ing the valve for about a week without luck.
Images:
Layout of Pool showing spa/pool/pool equip
Pool Equip Plumbing with shop vac blow pipe circled
Random valve that can't turn near spa
Thank you again!
Images:
Thank you again!
