New IG pool build in Nashville, TN
Will83
0
27
Nashville, TN
Soon to be first time pool owner... Interviewed many and selected PB last summer but with Nashville's boom, PB couldn't start until May 2018 with ETA late July. Please find pool details below with project photos so far...
Included in this proposal:
Engineered plans and building permits
Public liability, negilgence property damage and Worker's Compensation insurances Cleaning up and hauling away of all construction debris.
Detailed explanation of construction program for the homeowner.
Complete instructions for all supplied equipment
Maintenance equipment includes:
- 16" wall brush
- leaf skimmer
- 16' telescopic pole
- backwash hose, if applicable - chemical test strips
- start-up chemicals
POOL BASE
104 Linear feet of Perimeter
545 Square feet of Surface Area
987 Square feet of Internal Area
17372 Gallons
31 Linear feet of Steps, Benches & Sunshelves
14 Ln. ft. of 24" Raised Pool Wall Structure above bond beam/waterlevel
SPA BASE
28 Linear feet of Perimeter
49 Square feet of Surface Area116 Square feet of Internal Area874 Gallons
SECURITY DEVICES
2 Required Katie Beth's Law pool alarms
EXCAVATION
Complete normal soil condition excavation with all dirt to remain on site unless haul-off is specifically included below. Rock dig is not included in this proposal.
Finished elevation to be within 10" of existing grade.
14 Soil & excavation spoils haul away
POOL & SPA PLUMBING
All plumbing lines will maintain 30 lbs. pressure through construction
POOL PLUMBING
50 Linear feet of filtration piping from equipment to the pool
1 Automatic water fill device
2 Venturi-style EcoSkimmer
SPA PLUMBING
60 Linear feet of filtration piping from equipment to the spa
80 Total number of therapy air jets
POOL & SPA EQUIPMENT
CARTRIDGE FILTER
1 420 sq.ft. Clean & Clear Plus GPM Rating 210
FILTRATION PUMP(S)
1 IntelliFlo 2 VST variable speed pump
ADDITONAL PUMPS & FILTERS
WATER FEATURE ACCENTS
BLUFLAME METAL SCUPPERS
3 6" Stainless Stell or Oil Rubbed Bronze Scuppers
UNDERWATER FOUNTAINS
3 A&A Splashdown 22
ADDITIONAL PLUMBING & VALVES EXTRA PIPE, VALVES, ETC
330 Pipe 1-1/2"50 Pipe 3"
6 Ball valve 1-1/2"
1 2-way Compool valve (2" to 2.5")
3 3-way Jandy valve (2.5" to 3")
2 Check valve 2" to 2.5"
1 Upgrade to dual suction channel drain in lieu of suction side base
HEATERS
1 400K BTU Master Temp NATURAL GAS
CHLORINATORS & OZONATORS
1 QuikPure 3 Ozone System up to 25,000 gallons (uv light)
1 Rainbow #300 in-line chlorinator
CLEANING SYSTEM
1 A & A QuikClean® Xtreme TM Select In-Floor system
21 G4 cleaning heads
PROPANE & NATURAL GAS
1 Gas installation base
100 Linear feet of gas line
1 Gas permit - Nashville
STEEL
Per Ammtec Engineering Specifications
3/8” rebar on 12” centers throughout pool
3/8” rebar 6” on centers vertically at break and coves in deep end of pool (over 5 Ft. depth) Four (4) 3/8” rebar bond beam
Steel blocked on vertical walls and floors
28 Number of bars of steel for additional steel surcharge
ELECTRIC
All electrical includes bonding as required by building codes
4 Quantity of LED POOL/SPA light(s) with 100' cord
AUTOMATION EasyTouch:
1 EasyTouch 4 with 2 actuators
EasyTouch / Intellitouch Extras:
1 ScreenLogic 2 iphone/ipad Interface w/ wireless kit
1 Additional actuator valve
SHOTCRETE
Shotcrete to attain a minimum 28 day compression core of 4,000 P.S.I. average 8” on floors and walls, 8” minimum incoves and stress areas
6” X 12” bond beam
POURED CONCRETE & ACRYLIC FINISH DECKING
Pool and spa perimeters to be pitched 4” of concrete, covered with Acrylic Decking, pitched 1⁄4: per Ft. for proper drainage1 Loads of gravel required for 4" under deck Load = 20 tons
STEP RISERS
45 Linear feet of step risers, up to 8".
TRAVERTINE, NATURAL STONE & WOOD PAVER DECKING
TRAVERTINE PAVERS:
1 French Pattern
624 Sq Ft. of Field Pavers
COLOR BLEND %
100% Silver (Level 3)
COPING 3cm WITH BULLNOSE
185 Linear feet of Level 1
TILE
Waterline tile needed pool, spa & NE 132 ln.ft. required
1 Level 1 Waterline Tile Grade-Blue
STONE & BRICK VENEER
83 Sq. Ft. of Natural Stone Veneer
INTERIOR FINISH
1 Pebble-Sheen Premium (Cool Blue*, Ocean Blue*, Prism Blue*, Seafoam Green, Slate Blue*, Turtle Bay*)* Finish includes Shimmering Sea seashell blend in the mix
1 Pebble-Sheen spa with pool
MASONRY
Retaining Walls with Footer up to 47" (4 ft plus requires engineering )
66 Square feet of retaining wall with footer
OUTDOOR KITCHENS & ARBORS
GRILLS & KITCHEN COMPONENTS
1 Bull - Lonestar drop in grill
1 Bull - Single horizontal door
1 Bull - Premium outdoor SS fridge
OUTDOOR KITCHEN STRUCTURES
10 Ln. ft. of kitchen
I would tell him to keep the test strips and order a TFT100 test kit when your pool is about to be filled.
Definitely delete the Ozone system.
Consider doing a Pentair SWG instead of an automatic chlorinator.
You probably have to go with the PB startup chemicals for a while to maintain his warranty. You should compare what he recommends with what Pool School and PoolMath recommend.
Good luck with the build.
That plumbing is a piece of art. If the rest of the pool is like that you have a quality pool builder.
Only thing i dont like is that small pipe in the air over your pumps. It will be an annoyance anytime you need to work in the area. I would have ran it along the wall then out after the pool equipment.
AtWdf++mTuWE+iiB0yD%GQ.jpgHHyHQ5RjTTaFUdCC9E1zrQ.jpgmavZysKwTsKj1hFIQO0i5A.jpgCHTI+CAwSfiOwnKwnClg3g.jpg
Thanks Allen, I'll ask PB. I also don't like the Automatic water fill pipe location.
