Hi everyone. I'm Amanda and I live in Texas (near Houston so it's hot and sunny all the time) and have a new 14' x 42" Intex above ground pool with the Krystal Clear Saltwater System and Sand Filter Pump. The husband took care of our previous above ground pool and it was just constantly being shocked when chlorine tabs didn't fix whatever was wrong so I've decided I'm going to learn how to take care of this one properly. We've got 3 kids who live in the pool on the weekends and sometimes during the week too!
I've been doing a ton of reading here and on other sites but I have some problems that I'd love some advice on. Forgive me if any of this was dead wrong but I'm trying to figure it all out!
When we first got it set up about 2 weeks ago we added 2 40lb bags of pool salt based on the chart that came with the SWG (our capacity is 3357 gallons). I had ordered one of those digital testers from Amazon and the next day when I tested the salinity, it said 1900ppm so I added some more (maybe 15lbs). When I tested again, it showed 2400ppm but the brand new SWG switched off because of "high salt". He got some test strips at Walmart while I waited for K-1766 kit to come in the mail and they showed 4200ppm.
Sooooo we drained some water this past weekend and replaced with fresh and now the salt is doing better at 3210ppm when I checked yesterday. I also added CYA through a black sock hanging in the water and it was at 100 yesterday (even tho it's been at 50 the previous 3 days and I haven't added any more).
While we were dealing with that, I threw in a few cups of bleach. I can't convince hubby that this is okay but I did it anyway.
The SWG runs for 5 hours. The sand filter for 10-12 I believe. The water currently looks and smells okay but the numbers are telling me it won't last long.
Here's yesterday's numbers (based off test strips):
0.0 FC
8.4 pH
240 TA
500 CH
100 CYA
3210 SALT
The numbers the day before were:
1.0 FC
7.8 pH
240 TA
500 CH
50 CYA
4400 SALT
What do you suggest I do at this point to correct things?
Do I lower the pH and TA first and then deal with FC?
Do I need to worry about CH on a vinyl pool?
We don't have a vacuum right now and hubby says it won't do any good to get one because the bottom of the pool isn't perfectly flat because of the ground underneath (don't ask... it's not horrible tho). He manually vacuumed it out with a hose this weekend but there's got to be an easier way.
Any other suggestions you have for me?
Thank you!
0.0 FC
8.4 pH
240 TA
500 CH
100 CYA
3210 SALT
1.0 FC
7.8 pH
240 TA
500 CH
50 CYA
4400 SALT
Thank you!
