Hi all! Hoping to find some help here. My pool store is about to kill me on supplies, and we STILL can’t swim. I have an intex above ground chlorine pool... 18’x36’x52” rectangular with a sand filter.
My issue is this: I opened the pool a month ago. Vacuumed the leaves and debris, super shocked, vacuumed again, repeat... all of the debris is gone, and the water is not deep green, but now it’s a lovely shade of aqua/teal and so cloudy you can only see about a foot deep. My chemicals are reading as follows:
CL: 4
PH: 7.2
TA: 130
CH: 120
CYA: 20
(I see here on TFP that chlorine is registered as FC and CC. The kit I’m currently uses shows CL as “total chlorine” which I’m assuming would be the same as FC?)
That being said, the pool store had me use a product called Back to Blue. I dumped two canisters plus two lbs of shock in the pool, ran the filter for 15 minutes, and then dumped two of the kits second canisters (which looks like red dirt) and ran filter for 2.5 hours. Shut everything off and allowed to sit for 48 hours, at which point I vacuumed to waste, again. Technically the pool should have been clear at this point, but nope! Please help!! I’m at a loss and my kids desperately want to swim! Any advice to help clear this up so they can get in would be greatly appreciated! TIA
CL: 4
PH: 7.2
TA: 130
CH: 120
CYA: 20
