Thread: HELP ! First time closing IGP in NJ
    I have read several threads and have some questions.
    Sorry I am new to this. I have an gunite IG pool, solid pool cover attached via elastic bands to grommets in the cement deck.
    WHAT IS POLYQUAT?
    1. In order to remove the h2o I just have to place my gas powered leaf blower in the skimmer after the basket is removed? Will this force the water out of both returns or should i close 1 return valve at a time to increase pressure. I can then cycle through each return to remove the h2o. Does the main pool filter controller remain in the normal operating position or changed to pool close during the process. Doesn't the pressure from the blower with water in the filter damage the fins of the my DE filter?
    2. What chemicals have to be added to the h2o prior to closing? chlorine levels? winter algaecide?
    3. Last year my pool closer did not add any antifreeze to the lines. Just lowered h20 1/2 way down between top of pool and top of the returns. Of course it was lower than the skimmers. The lower my H2o level is, the more stress on my solid pool cover.
    If I add pool antifreeze where do I add it and how much? Do you add it instead of blowing out the lines? What would the sequence be?
    5. Heater- all I need to do is turn off the gas main?
    33,000 in ground gunite pool with heater, automatic chlorinator and D.E. filter.
    Switched over to liquid chlorine and baking soda this season and very happy. Saved MUCHO $$$$$$$$.
    I bet my pool store "buddy" is wondering where I went to, along with the 100's of $.
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Re: HELP ! First time closing IGP in NJ
    Welcome to TFP... just in time to close your pool, eh?
    Other bonafide northerners on this site will answer the specific questions you have about closing operations. I would just want to direct your attention to this thread, which explore the basics of closing.
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    polyvue's Avatar
    Aug 2009
    1,215
    Bump?
    __
    The heater should have drain plugs which need to be removed and stored for next season. On my heater, I need to disconnect a flexible copper pipe from the pressure switch to get all of the water out.
    15,000 gallon unpainted plaster. Sand filter. Polaris 380.
