My pool is 4 years old, and despite being a loyal TFP follower during this time (I've never used a "pool guy" or had water tested at a pool store) I believe I have been living with mustard algae pretty much since the pool opened. I've been bad about adding chlorine to the pool at night, testing the following night, seeing near zero chlorine, then dosing the usual amount again before bedtime. Little to no CC's because basically all the chlorine burned off during the day -- I'm also terrible about maintaining CYA. I simply cannot get CYA to stay in my pool so it tends to drop off to less than 20.
We always have slippery "dust" on our steps and tanning ledges, especially in the shady parts of the pool. The water has always been crystal clear, and I've never seen green algae in the pool. My pool is gunite with an extensive gunite waterfall feature (3 waterfall pumps, cave/slide, etc). We have noticed that when we use trichlor tabs our CCs are always around 2 and the water smells funky. This year, I recognized the problem and decided to fight back.
The fight:
I slammed the pool using liquid chlorine (testing the water about every 4-6 hours) for almost 2 weeks straight. I also used trichlor tabs to augment this process as my CYA was basically zero to begin with. I stopped using tabs when my CYA got to around 40. During this time I brushed the pool daily -- and discovered that my waterfall "rocks" that extend under the water line are excellent algae hiding spots. I actually swam around in the pool (showering immediately afterward) and brushed these areas by hand as they are almost impossible to brush otherwise. I cleaned the filter (cartridge filter - sprayed off with a hose), cleaned out skimmers and pump baskets. I took the shock level up to mustard level several times and left my pool brush/pole in the water just in case. I pulled the lights out of their niches and scrubbed inside - and left the lights out during the slam. Despite this, my chlorine losses were tremendous and never improved. My CCs were occasionally 0.5-1, but more often (and inconsistently) 1.5-2. I never achieved criteria to proceed to a true OCLT, but the losses would sometimes be double digits overnight. After 2 weeks of this, I decided that this method was untenable and prohibitively expensive. I must have used an entire semi truck load of liquid chlorine during this time. I next used Yellow-Out (I'm desperate) which initially seemed to help a little with the visible clouds of algae seen nightly when I brushed, but as expected made the pool smell of ammonia. This eventually (with tons of chlorine) went away, but I'm back to the same old algae problem now. I've added Polyquat 60 without noticeable results. If I shock the pool every night, the algae buildup is less but my CCs are high. If I add the usual amount of chlorine (6 ppm for my pool), then my CCs (and FC) are low, but the algae returns.
I am seriously about ready to give up and just drain the pool and have flame throwers sterilize it. I cannot figure out why the algae doesn't die, or where it could be coming from. I do have a Nature2 chlorinator - and I have never changed the nature2 cartridge. Could it be an algae bomb seeding the pool? Also, I bought cheaper non-Hayward brand cartridge filters last year when I replaced my cartridges. Not sure if that would matter much. I'm regretting building a pool with such extensive underwater "surface area" that is hard to brush --waterfall fake rocks and flagstone beach entry.
I welcome any and all ideas/suggestions, and thank you all in advance.
My FC/CC results fluctuate as describe above
CYA had been as high as 40, now back to around 20 (seriously - I can't keep CYA in my pool...)
pH is usually around 7.8-8 (my fill water is unfortunately pH 8.2 with super high TA - I have to add acid every other day)
The fight:
