- May 13, 2013
- 40
I'm putting up a 14 foot Intex Prism Frame pool this year (instead of my usual Easy Set). I upgraded my pump to the Intex 2,500 gallon, so I also purchased hose converters. I also purchased the waterfall (one of the main reasons I wanted the Prism this year instead of the Easy set - haha), so I was able to use the larger hoses on the return side as it came with a converter attachment the goes directly into the pool, but I can't figure out how to make the larger hoses work on the intake side. Is this setup OK? Should I try to use the smaller hoses on the return side too? I have attached pictures. I probably won't get a chance to test it for a day or two as the pool just started filling and usually takes at least a day or so. I just don't want to ruin the pump or anything. Thanks!
