I just got automation and a new SWG installed by LPS. The pump is scheduled for 8 hours run time during the a.m. My problem is the SWG does not turn on when pump is running. I called the installer and he said the SWG was wired to AUX 1 and said it should turn on when pump turns on. This however is not the case.
After reading the Intellitouch installation manual. The way I understand it is that the SWG should have been wired together with the pump filter relay. What is the advantage to wiring it to the Aux relay as installer had wired it? Should the SWG get wired to the pump relay? If wired to AUX 1, what would/should command the SWG to turn on?
