This spring we had our gunite pool re-plastered with hydrazzo. Upon completion, about three weeks ago, we immediately had the pool filled with water by delivery truck. I use the TF-100 test kit and have everything in balance except the TA is high at about 190-200. It started at 240, so it has come down a bit, but I need to get it down further. I have been following the procedure to lower TA from the pool school instructions. I just added another gallon of muriatic acid to get the Ph to 7.0. I have my waterfall, jets and fountain running to create aeration. My understanding is that adding the acid will lower both the TA and Ph? I originally thought that the aeration eliminated the high TA, but now in reading it sounds like this is simply to increase the Ph without increasing TA. Frankly, I tend not to have a problem with Ph being low. In fact with the new plaster and the SWG creating liquid chlorine I generally add muriatic acid a couple of times a week to keep my Ph in balance and from being too high. So, I am a bit confused. Is the acid the only thing I need to lower TA and the aeration is not necessary as long as my Ph is good?
