- Aug 3, 2015
- 175
- Plaster
- Pentair Intellichlor IC-60
Hi all,
Is anyone familiar with how to set up a IntelliChem to dispense by time instead of based on trying to hit a ORP setpoint?
I've had a EasyTouch 8, IntelliChem with a 4-gallon acid tank, and IntelliChlor IC60 for a couple of seasons now. I've never been able to get the ORP to work right, as the ORP value is never consistent with the FC level, despite me being very mindful about proper chemical balance, etc. The only thing I'm not doing is keeping the flow cell out of the sun - I heard that can help things, but all my equipment is outdoors. I've already gone through 3 ORP sensors, so I know the sensors aren't broke. The pH automation is great though. That being said, I'm giving up on the ORP value to control my IntelliChlor's chlorine production. I'd like to try using the IntelliChem's dispense by time option. I'm posting here because I don't know how to set it up correctly. I know that the first step is switching the ORP dosage setting to be by time instead of by setpoint, but what do I do from that point? In other words, I see that there's a dose time I can set (which is defaulting to 11 hours since I keep my system on 11 hours a day), but it that the only option? That I can just tell the system how long to run the IntelliChlor for each day? Does the percent setting via the EasyTouch also relate to this? For example, that's currently set to 50%, so does that mean the IntelliChlor will run for 11 hours a day at 50% if I leave everything that way? If yes, then it isn't working right for me as no matter what the IntelliChlor has all of its sanitizer output lights lit to indicate that it's running at max strength all the time.
