I set up a 15 foot/42 Inch Intex above ground pool on Wednesday.
To begin I added Canadian Tire Aquarius Shock treatment.
Thursday:
Tested water with the following results:
Using test sticks, does not show a reading for stabilizer?!?!? Perhaps I am better off purchasing other type of water test.
Step 1 - Your Total Alkalinity level is high:
Use 2.8 KG of AQUARIUS PH REDUCER. It will prevent scaling of your pool surface and equipment and increase bather comfort.
Step 2 - Your Stabilizer level is low:
Use 436 g of AQUARIUS POOL WATER STABILIZER. It will prevent sanitizer loss.
These results recommended that I use pH Reducer and Water Stabilizer
This evening I added 1.4 kg of PH Reducer. (Will retest tomorrow and add the other 1.4 kg recommended)
I have not added the chlorine pucks as of yet as I was told to balance pH/Alkalinity first. Once this is done, I believe 1 puck per week should be enough.
Do I wait till my "Free Chlorine" is lower?
Also what about CYA?
Am I on the right path?
I appreciate your help!
Thursday:
Parameters | Value | Recommended |
Total Alkalinity | 240 ppm | 80 - 120 ppm |
pH | 8.4 | 7.2 - 7.8 |
Free Chlorine | 5 ppm | 1 - 3 ppm |
Stabilizer | 0 ppm | 30 - 100 ppm |
