Thread: Pool creaking and unleveled
    May 2018
    Harrisburg
    2
    Unhappy Pool creaking and unleveled
    This is my second year putting up pool. I got the pool at the end of summer and used it for about a month. I tried leveling the ground and it wasn't leveled. It did good for the remainder of summer. This year I decided to move it a little so it would be more leveled. Unfortunately it's still unleveled about 3 inches at 2 poles. I also noticed the pool creaks when someone is in it. Should I try leveling ground again and put pavers under pool?20180507_194213.jpg20180507_194213.jpg
    Intex ultra frame 16x48 above ground pool
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    Re: Pool creaking and unleveled
    Within 1" of level is what is recommend. You risk the pool failing when it is more out of level than that. If you can hear the pool frame making noise I certainly would try and get it more level than it currently is. A bursting pool can cause personal injury and will cause property damage.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    May 2018
    Harrisburg
    2
    Thanks I'm going to drain pool today.
