- Oct 25, 2015
- 5,826
- Plaster
- CircuPool RJ-60 Plus
It is definitely 5/16 of an inch. I tried to take a photograph but I couldn't hold the camera and everything to get the photo of it. I was down at eye level looking straight at the ruler all around the pool. I did find one low spot that's actually on the house side of the spa that's a little more than 5/16 of an inch maybe 3/8 so when I turn the pool off that is where we drain from last. I'm very pleased with the level on that inside wall. As you can see from the first video we had that formed up after the gunite work and the top of that form work took a lot of time to get right. We double checked it frequently with a bubble level, and my zip level and a water level.It's hard to tell, but it does not look like 5/16".
It is very difficult to get an accurate measurement.
If you get a flowmeter and some vacuum and discharge pressure readings, then we can better assess the flow rate.
I know that 4" pipe seems big, but it might be a little bit undersized if you want to get the full flow from both pumps on the Infinity edge.
You definitely need to get the heater off of the Infinity Edge loop.
