I need help understanding how to set up some automation on my pool. I an using the Iaqualink which has the One Touch features that include filtering, Spa, and Drain Spa. I can't figure out what the proper setup should be on the actuator that directs flow to and away from spa jets (see attached pic). My wish seems to require 3 various positions of the acutuator and if I do not leave the actuator in the closed spa return jets position, most of the water drains out over night back into the pool..
1. Spa mode, the water flow into the spa as normal
2. Regular filtering I want (or currently are doing) it to flow to spa and spills over to pool and some water is sent to the pool wall returns (is this correct?)
3. Spa drain will need to block spa jets and return all water to pool.
