Went for it and opened the pool yesterday, I don't get the tornado effect I would expect, but it is pulling. I plan to add DE powder this evening after my first test with my TF-100, and I'm just concerned its not pulling enough. I'm not 100% sure all the air is out of the system so that may be the issue. All of my jets seems to be working as the 6 port valve allows. Pressure runs about 14 PSI if you need this info. Side note I only ran pump yesterday long enough to confirm everything was working so maybe 30 min or so that may not be long enough. I still get air and water when I open the valve on top of the filter.
TKS
TKS
