is there a different SWG that has better cold weather performance than Pentair?
This is my first winter after adding SWG. I added salt to my pool when "opening" it a couple weeks ago. (This is Dallas so it never really closes, but I pay less attention to chemicals over the winter.) From Feb. to March my EasyTouch reported that salt level went from 2250 to 1050 ppm. I ultimately added 400# salt and reported level only got to 2550. I had water tested at Leslie's and they showed 3500 ppm. I called Pentair and they confirmed what was reported in this thread...
https://www.troublefreepool.com/threads/94103-IC40-shows-0-salt-but-cell-on
Thank you for contacting Pentair. In response to your inquiry, the cell reads accurate salinity at 77F. For every degree off from 77F, the cell will miss read salinity to a factor of 70PPM. For example, if the salt content in your pool is at 3300PPM and water temp is at 50F.. the cell will read salinity at 1410PPM giving a low salt condition in error. If the water is at or near 77F and you are getting low salt condition and no chlorine production... this would indicate that the flow/temp sensor may need to be replaced (part number 520736).
That calculation works out perfectly for my 63 F water. Problem is, no chlorine is produced below 2600-2700 ppm and I don't want my "real" salt level much higher So two questions.
1. If I get barely over the threshold for generating chlorine (even though actual salt level is high) will chlorine production be normal, or will it be limited?
2. Is there another SWG that works better in lower temps?
Since my IC40 is pretty new, I will hang on for now with bleach, but looking to the future when SWG needs to be replaced.
Bill.
Bill.
