I mean the intellichlor. In any case, the salinity is not reading correctly and I would suggest a warranty claim or just swap out the sensor yourself or get a 10k thermistor and put it in the pipe and wire that to the thermistor wires or raise the salinity until the cell works.
I think that your salinity will be much more accurate with a new thermistor.
The Pentair, Hayward and Jandy/Zodiac 10k temperature sensors are all similar. You can use any one of those or a generic.
The flow switch contains two parts. A flow switch and a temperature sensor. If you replace the part, you have two sets of wires. One set goes to the temperature sensor and the other set of wires goes to the flow switch.
The temperature sensor is the only bad part. So, you can just use a different sensor and wire it in without removing the old flow switch.
This will probably void the warranty so don't do it if that matters to you.
HAYWARD GLX-PC-12-KIT GOLDLINE TEMPERATURE SENSOR - 15 FT
https://pentairpool.com/~/media/websites/pool/downloads/sanitizers/manuals/intellichlor_flow_switch_replacement_kit_installation_guide_english.pdf
You can test the temperature sensor by cutting the green and white wires to measure the resistance of the thermistor. It should match a 10k thermistor chart. For example, at 77F, the resistance should be 10,000 ohms (10k ohms).
