- Jan 5, 2016
- 79
- Plaster
- Pureline Crystal Pure 40,000
Hello there. I have been a member since purchasing my home in early 2016 and have been quietly lurking since.
I just signed to have my pool (and pool deck, patio, etc) remodeled and I'm excited to try to chronicle the progress as it happens.
Current state:
~18k gallon in ground plaster pool with spa
1 skimmer, 3 returns (all near shallow end)
Jandy DE filter (I think, its old and painted over)
Single speed pump for filter
Booster pump for vacuum
No heater
Work to be done on the pool:
1. We are having the spa filled in to give us more patio space (we never plan to heat it. we will get a standalone spa if we want warmer water)
2. We are also having a crack fixed (near the steps).
3. Shamu shelf being added with umbrella holder(s)
4. Shallow end being expanded. Current shallow end is small and drops off drasticall into the deep end
5. Adding 2 more returns for better circulation in the deep end
6. Resurface with Wet Edge Primera Stone (color TBD)
Questions:
1. Should I replace the existing light (1 in pool) with an LED (white or color)? I have no plans of ever doing any sort of automation
2. I plan to eventually convert to a SWG. Is there any reason to do this in conjunction with the remodel?
3. I plan to eventually replace the existing filter pump with a VS pump. The current pump works fine. Is there any reason to replace with a VS pump in conjunction with the remodel?
Thanks for the advice over the years (even though you didn't know you were giving it to me).
I'm excited (and nervous) for this remodel to begin. Demo starts on Monday!
-Changeyez
Current state:
No heater
Questions:
-Changeyez
