Thread: filter is putting sand in the pool
    Southgate, Michigan
    6
    Hello,
    I have a Hayward 1hp sand filter for my 10,000 above ground pool. I have noticed that I have quite a bit of sand on the floor, and always blamed it from when I placed a bag of sand (which I removed) to keep my wedding cake steps down. After vacumming the sand up, we placed a panty hose over the return and found the sand (plus some other dirt) were being returned into the pool. Please suggest what to do next, (although please speak slower.....like a 2nd grader, I'm new to this and get easily overwhelmed with machinery talk )
    10,000 gallon AG pool, Hayward 1HP sand filter
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: filter is putting sand in the pool
    Make sure it is sand first, if it is sand you will be able to pick it up with your fingers.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Southgate, Michigan
    6
    It's sand. I can pick it out with my fingers, its the coarse pool filter sand that went into the filter.
    Jul 2007
    Philadelphia
    17
    Make sure you use the Rinse cycle after backwashing.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    It sounds like a damaged lateral or valve seat gasket. unless the sand is a very very fine grit on a new installation.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
