Thread: Preventative Maintenance for a Sta Rite VS 3050
    May 2011
    No. CA
    118
    Starting April 5th, I'm getting new plaster and tile and the pool will be down for about 10 days.
    Pump was replaced in 2011 when I added Solar.
    Is there any preventative maint I should consider to the pump? It is a sta rite VS 3050.
    I think it is not as quiet as it was when brand new, but I don't think the bearings can be replaced on this motor.
    Is this best to leave it alone? or should I consider a seal, check/replace impellor? other?
    tnx
    Pool IG 17,000 gallon (33 x 16) Spa IG 700 gallon - under renovation
    Sta-Rite IntelliPro VS 3050, Pentair Easy Touch 8, Intellichlor IC40, Pentair FNS Plus 60, TF-100 Test Kit w/ salt test
    Pentair Intellibrite 5G Color LED, Polaris 360, Lars Lx400 NatGas heater, Fafco Solar panels
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    35,055
    Re: Preventative Maintenance for a Sta Rite VS 3050
    My gut says leave it alone but here is a bump to see what others have to say.
    sktn77a's Avatar
    Chapel Hill, NC
    738
    Quote Originally Posted by Dan-H View Post
    Wish I had a dollar for every time I've heard this!!!
    Seriously, though, you could take this opportunity to put union couplings at the inlet and outlet of the pump (if you don't already have them) so that if/when it obviously need service in the future, it won't be a replumb job at the same time.
    Keith
    15,000 gallon in-ground gunite/plaster pool, 1.5" PVC plumbing
    1.0HP Sta-Rite DuraGlass P2R pump, Hayward S244T sand filter
    Teledyne-Laars Lite-2 250k heater, Hayward CL200 chlorinator
    Polaris 380/Hayward 6060 booster pump
