Thread: Hayward Low Salt SWG
    Aug 2017
    Toronto, Canada
    80
    Not sure if this is an "Only in Canada" thing but has anyone used Hayward's Low Salt system? I think they started it due to local max salt limit when draining into the city sewer system.
    My ProLogic 8 has the option of running in Low Salt mode with a T-15 cell only. Since I have a fairly small pool (6,000gal) does it make more sense to run the SWG at a lower % and higher ppm (2,700-3,400) or at a higher % at a lower ppm (1,200-1,800)?
    Pool: 10'x20'x4' - 6,000gal - Vinyl Liner IG - Hayward Maxflow VSP SP23520VSP - Hayward H250ED2 250k - Hayward Prologic 8 - Hayward T-Cell-15 SWG - Hayward 24" LED waterfalls (x3) - Hayward GVA-24 3-way - Hayward Aqua Connect - Hayward Wireless Table top Remote - Pentair Posi-Clear RP Cartridge filter 200sq - AquaLamp 12v LED multicolor pool lights (x2) - Inline Zinc anode rod
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,844
    Re: Hayward Low Salt SWG
    I guess that depends on your local discharge by laws
    At this time, I think the low salt unit is only available in Canada.
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Aug 2017
    Toronto, Canada
    80
    My current city doesnt have a bylaw against it
    Not sure if having a pool with a lower salt ppm is better than a higher (see original post)
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,844
    I think traditionally, higher salt pools are likely more efficient at producing more chlorine, and that a lower salt configuration was developed as a response to environmental concerns. Environmentally, there are concerns about the impact of discharged salt water on freshwater watersheds.
    Functionally, I'm guessing a cell might last longer generating in a higher salt pool.
    If the swg is retrofit and if the pool in question has stainless steel elements, a lower salt environment may theoretically reduce corrosion/prolong lifespan of metal elements proportionately.
    These are "best guesses" on my part...might be worth asking Hayward. But the choice if not governed by bylaw would be a personal preference on your part.
    Eg. If I had a low salt option available I might consider it even if it meant I spent more on cells every so many years because I live on a hill near a freshwater river with a sand filter that gets backwashed, and as such, I do have a concern about contributing unwanted salinity to my local watershed...but obviously not concerned enough to have forgone the convenience of the swg in the first place
    Helpful Links:
    uxbridgechris's Avatar
    Jan 2018
    uxbridge, Ontario Canada
    560
    I'm gonna get a desalination system. Dump clean water into sewers and salt into my salt shakers.
    Blue Hawaiian “Wellington” FG pool 6500 Gal. Raypak 266 NG Nickle plated, 3/4hp Hayward super pump, Heater Reader wifi / app controller. Pentair 420 sq' cartridge filter. Hayward 25k SWG
    Pal LED pool lighting. Jandy K-1100 Electronic Autofiller Build thread here: 2018: Fiberglass install uxbridge ointario
