Results 1 to 12 of 12
Thread: Polaris p380 Problems
    Feb 2018
    Conroe TX area
    27
    Thumbs up Polaris p380 Problems
    Hello,
    I am a new pool owner and my pool has a Polaris p380. Anyways, it will not sit flat, and it turns on its side constantly. I have tried adjusting the jet on the back and the sweep hose screw(my sweep hose is also not sweeping, maybe that is related). I will take the hose and set it upright but as soon as it hits a wall it reverts to its side, or it climbs halfway and the bottom stays up as it goes across the pool. Also, the bag is empty and the float does not have any water in it. Thanks for your help!
    15000 Gallon IG Gunite Pool(White, redone late 2016), Single Speed Switchless (AO Smith Centurion motor) Pump, Polaris P380(Ugh), Pentair booster pump, Hayward Pro-Grid DE4820 filter, 1 skimmer, 1 MD, salty, soft, and absurdly expensive Texas public water.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    4,231
    Re: Polaris p380 Problems
    Hello! Welcome to TFP. I'm sorry I don't have a suggestion on what is wrong with your vacuum. You are not the first person to hear my spiel. My vote is to ditch the Polaris a get a robot. In order to run your vacuum, you have to run your pump AND your booster pump, using much more electricity than necessary to clean your pool. To run a robot you plug it in and throw it in (drop it in actually to be safe). Our Dolphin robot (see link in signature) cleans much better than our pressure side vacuum did, which was a similar style to yours. Ours mostly went in big circles, not getting to the shallow end and cleaned poorly. I didn't realize how poorly until I got a robot and the dust-like debris wasn't there anymore. Both captured leaves except that the our old vac only hit less than 1/2 the pool.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    35,043
    How is the pressure in your filter? I wonder if it needs to be cleaned. Do you know when it was last cleaned?
    Feb 2018
    Conroe TX area
    27
    I just backwashed today, it is now 20 psi. Also, the booster pump works fine.
    Mar 2010
    129
    When both pumps are off, does the cleaner set upright in the pool with the rear wheel just off of the floor? That's what it is supposed to do.
    Hard to say, but it sounds like the vacuum jets are clogged, or there is an issue with the internal plumbing. Possibly a backup valve issue. Should be a relatively quick easy fix for someone who is knowledgeable in the workings of the 380.
    I will respectfully disagree with the previous post, who blindly suggested that you ditch the 380 and drop close to a grand on a new cleaner. Those of us who actually work in the industry know that there is no single one size fits all "best" solution to every pool out there.
    Take it to a pool shop, or have a tech stop by. It can be as simple as an internal hose popped loose.
    Jul 2012
    Tallahassee, FL
    35,043
    So next up would be for you to pull out the owners manual and go over the cleaner with a fine tooth comb looking for what could be causing this. Is something loose? missing?
    How old is the cleaner? When did it last work right?
    Kim
    bmoreswim's Avatar
    Jul 2012
    Central MD
    4,231
    Quote Originally Posted by Mayorb View Post
    Agreed that it is good for pool owners to know their options.
    Feb 2018
    Conroe TX area
    27
    Yes, bmoreswim's post was very helpful to my case. I have taken it apart and checked everything. I don't know exactly how old it is as it was purchased by the previous homeowner. When it is off it does not usually sit upright, and the backup valve works fine. It last worked good in November, so it may be a loose hose or something.
    Feb 2018
    Conroe TX area
    27
    Would adjusting the hose that supplies water at the top of the polaris help?(I moved it back and I think it was bent over time to where it was)
    May 2017
    Houston
    23
    Head float has water in it.
    Feb 2018
    Conroe TX area
    27
    The head float does not have water in it. I took it apart and replaced the bearings, supply tube o ring, gear drive kit, and belts and it all works fine now.
    May 2017
    Houston
    23
    Weird.
