Thread: Hooking up vacuum correctly?
    goody222's Avatar
    Feb 2018
    Chesapeake, VA
    73
    I just wanted to confirm that I'm vacuuming correctly from what I learned in pool school from the builder.
    I put my 2 speed pump in High Speed.
    I completely submerge the vacuum and hose insuring it is 100% filled.
    Then shut off my 2 drains and reach in 1 of my 2 skimmers to move that plastic piece over to stop flow.
    I connect the vacuum hose to my other skimmer and start vacuuming.
    My main question is: I was told that whenever my pump is in HIGH speed during normal operation, I should ensure the pump basket filter shouldn't have any big bubbles in it. When I vacuum per the above procedure, the pump filter basket is only about 50% - 70% filled. Is this expected when vacuuming (almost makes sense being that you're only pulling flow from 1 of 4 suction lines)? Am I doing something wrong? Hope I'm not damaging the pump. Thanks!
    26k In-Ground Vinyl 38' x 18', Hayward Aqua Plus with Goldline T-Cell-15 SWG, Hayward TriStar 1.5 HP Pool Pump (2 Speed), Swimclear Cartridge filter C200s, Hayward Booster Pump (6060), 2 Hayward Colorlogic 4.0 lights
    Gemini style with jump rocks and waterfall, Taylor K-2006 / Speed Stir, Seven 4x12 'Solar Industries' Solar Panels on 2-story roof, Built 2017 in Chesapeake, Virginia. -Mark
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,913
    Re: Hooking up vacuum correctly?
    Goody,
    When I used to vacuum, I found that I could not suck enough water through the hose to satisfy what the pump needed... To make it work, I had to adjust the valve so that the hose had about 80% of the suction and the skimmer about 20%..
    I had a valve at the equipment pad, but believe that you can do the same thing with the 'plastic part' in the skimmer. Try only closing it about 80 to 90 percent and see what happens...
    I no longer vacuum because I have a robot cleaner...
    JoyfulNoise's Avatar
    May 2015
    14,233
    When I vacuum, I have a 3-way valve that splits the incoming water from the skimmer/MD and the vacuum wall port. I never completely pull from the wall port as the pipe plus vacuum is just not capable of supporting the flow needed and a decent pumping speed. I probably split the flow like Jim says - 80% wall port, 20% skimmer/MD. That keeps the pump happy.
    Matt
    goody222's Avatar
    Feb 2018
    Chesapeake, VA
    73
    OK, split the flow it is! We'll see how next time goes.
