I'm in the process of planning a remodel of my IG 39x18 gunite pool. The quotes I'm getting from the pool companies to just replace the equipment are close to $5K . This is excessive as I can buy the equipment for about $2k. I'm going to replace all of the equipment myself (I've done it before). This will be a simple set up as there are no water features to deal with and no pressure type cleaner. There will be no pool automation system (I still have roll up windows in my truck). I'm going to go with a Pentair SuperFlo VS pump. I understand with this pump I no longer need a timer as the pump provides this feature. I want to install a IntelliChlor IC60.
My question is what is the preferred method for wiring the power source so the SWCG doesn't have power when the pump isn't running?
