- Nov 12, 2017
- 11,907
- Plaster
- Pentair Intellichlor IC-40
If the variable speed pump can be set between 600 and 3450 rpm in 1 rpm increments, then it's a 2,851 speed pump.
A variable speed pump adjusts the power frequency to control rpm.
A two speed pump uses two sets of windings, a two pole set and a four pole set to allow for two speeds.
Thanks JamesW. Yes, I get that. But in terms of how I can set it up to operate, low for filtering, medium for skimming, high for cleaning, etc. I have a four speed pump. A "very adjustable" four speeds, but while in actual use, just four. So I would label my IntelliFlo an "adjustable speed" pump. The ones that can maintain flow settings, now those I would define as "variable speed" pumps, because they can "vary" their speed while operating. Mine, I can only "adjust" it to run one of four pre-set speeds. Semantics.
Now if the pool industry had its stuff together, they could have systems that monitor the clarity of the water, the flow through the filter, energy use (including variables like PG&E rate periods), the amount of crud on the surface or bottom, the air and water temperature, etc., all in real time, and throttle (vary) the pump speed, on the fly, to constantly solve for any given condition in the most energy-efficient way possible. (They're part way there.) They could then call them "dynamic speed" pumps! Copyright © 2018 Dirk Engineering, Inc.
Interesting about the windings. So those motors would not be user-adjustable. But I could swear I just read a few days ago, here somewhere, that someone knew how to dismantle or otherwise go inside a two speed pump and adjust in some way the RPMs of the two speeds. I didn't get the impression it had an onboard controller, like an IntelliFlo. This was something more rudimentary, that was like a set-it-and-forget-it adjustment. So that, if one needed a bit more or less RPMs on either setting, you could go in and tweak that speed. Did I imagine that?
I brought up the notion of variable or adjustable speeds for how Technikal could further pursue his energy savings. (Not that he necessarily needs to or wants to. Just jabbering to myself.) He's replaced his motor and now has a lower speed. He's getting savings. He's got a run-time constraint with his SWG, so he's stuck there in terms of savings. So what's left is finding a way to adjust the RPMs lower to use less electricity. He also needs a certain amount of RPMs to keep the leaves at bay. But if he could lower his low speed (while maintaining clarity) and briefly ramp up to his also-adjusted high speed for skimming a few times a day, controlled by a timer that can handle his two-speed, then he could conceivably eek out more savings while keeping his pool just as clean. Unless, like I said, I've imagined this whole adjustable two-speed motor thing.
I had a client that had invented a gizmo that bolted onto refrigerator fans, like in commercial refrigerators. It somehow controlled the fan speed, which greatly reduced energy use, while not compromising the motor. Not sure exactly what it was doing. Something like that might be useful in the pool industry, if it could be repurposed somehow, assuming the gizmo was less expensive than a pump/motor upgrade. You could just bolt it onto your old one-speed or two-speed and get instant savings. They sold the tech to some big refrigerator company. Their website explains it a bit.
OK, I think I just used more electricity typing this than the idea of it will ever actually save anyone!! :blah:
