Thread: Automating Heater with Hayward Ecommand
    Hey guys,
    Just put in a new pool, I was the contractor so had to wire up all the automation myself. So maybe this is a newbie question! I have a Hseries hayward natural gas heater 350k, a hayward ecostar pump, and a Ecommand 4 with remote. I've tried to learn the complex menus in the ecommand and i've "enabled" the heater in spa mode and set the temp to 104. I've wired the pump and heater to the ecommand panel. So here's what happens when Push spa mode button.
    1. Pump shuts down for 35 seconds
    2. actuators turn to appropriate spa mode positions
    3. Heater tries to turn on, with clicking, but eventually i get the LO error since no water is flowing since actuators are still turning and pump is off.
    4. Pump starts up.
    5. Pool is now is "spa" mode
    6. heater never comes on due to "LO" error
    So, I can see I can disable the pump from shutting off during the actuator/mode shift, and this I assume would fix the heater issue as there would be water flow. would this damage the valves over time? Surely there's a better way or something im missing, so that the heater comes on after spa mode is completely ready to go and pump is running again? Like a delay or something?
    Heater works fine if i manually turn it on when not in bypass mode.
    Thoughts?
    Thanks!
    22k gallons
    White Plaster
    Jandy DE filter
    inline 320 Chlorinator
    Polaris 280
    ps0303's Avatar
    Jul 2011
    FL
    3,948
    Re: Automating Heater with Hayward Ecommand
    No you won't damage the valves as many system don't shut off the pump while the valves turn. Just hopefully the valve by the pump doesn't turn in the direct that would tempoarlity deadhead the pump while it's turning.
    Paul
    Gastek Pool & Gas Services If you would like to provide a review of the help I provided, please use the following link to leave a review. Gastek Google review,
    Check out some videos on my YouTube channel - Gastekservices on YouTube
    Houston, TX
    1,371
    nog,
    you need to first make sure your pump is running full speed before you initiate the heater, otherwise the LO is telling you there's no enough water being moved through the system for heater to kick-on. The heater does have a delay, but not 35 seconds...
    You need to make the pump come on instantly in spa mode, not a 35 sec delay. If you do this, then the heater will come on after the pump is on and in spa mode...I personally like to initiate the heater to come on after I know everything is running properly - Also, what made you choose the ecostar pump? good luck
    InGround 15K gal, 18'x30' 3.5' to 5.5' depth w/ 9'x9' spillover Spa, Pebblesheen w/ Travertine, Hayward 3 HP VSP, Hayward C4030 Cartridge, Hayward 1.5 HP for 2 Scupper columns, ProLogic, PL-PS-8 Panel, Hayward H400FD 400K BTU Heater, 3 ColorLogic LED, Spa Blower, TF-100 w S-Stick, QC Tiger Shark, Autofill If you enjoyed your TFP experience, please consider donating to Support TFP!
    okay I disabled the cool off for the valves turning and somehow i got the ecommand to let me do the heater manual. so everything is controlled via my remote puck and its fantastic. Thanks for everybody's help
    22k gallons
    White Plaster
    Jandy DE filter
    Polaris 280
