Thread: Losing Water in Spa when Pool not Running
    Dave2112's Avatar
    Jun 2016
    Oklahoma City/Oklahoma
    17
    I have a spa that over flows into the pool when the pump is running. When the pump is not running, the water level in the spa slowly bleeds down. Maybe 3" over night. When I use the spa the water level doesn't leak down. I think that is because of the electric valves move to close off the pool. Do I need a new check valve?
    Thanks for your help,
    Dave
    25K gallon inground pool, diamond brite plaster with spa overflow. Pentair Clean and Clear Plus 520 cartridge filter, Pentair Master Temp 400K gas heater, Pentair 2.0 HP Whisperflow Pump, 4' clear descent water fall, Pentair 1.5 HP whisperflow pump for water fall and bubblers. Pentair Water pool and spa automation control panel with remote. TF-100 test kit.
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,854
    Re: Losing Water in Spa when Pool not Running
    Dave,
    Most times when a spa leaks down when the pump is off, the check valve is the cause..
    Depending on the type of check valve you have, you can just clean it out, or rebuild it. If one of the cheap PVC ones, your only option is to replace it.
    Dave2112's Avatar
    Jun 2016
    17
    It has a sight glass with screws all the way around it. I'll open it up and see if anything is keeping it from closing. Thanks for the quick reply Jim.
