Page 1 of 2 12 LastLast
Results 1 to 20 of 26
Thread: Pool size
    Jan 2018
    Manalapan
    7
    Pool size
    Is 36x18 freeform pool considered small? I have a 2 acre lot so space is not a constraint, was wondering if I should go for a 42◊20 Pool for an extra 2000$$
    Again I don't want to spend the extra 2k if 36◊18 Is plenty pool. Kind of concerned that the pool will really look small wrt to my home (5500 sq ft) and yard.
    Appreciate your input
    Thx!
    Aug 2015
    San Francisco Bay Area, CA
    129
    Re: Pool size
    I have a 36 x 16 rectangular pool. It is not small, but if I had the space I would take the extra footage for $2,000 for sure. One thing you should consider, however, is that the $2,000 is only the beginning. The larger pool will require more of "everything." What part of "everything" matters most depends partly on where you live. For instance, in California, we need to worry about droughts, and the larger pool will evaporate more water. If water is being rationed, you may not be able to get the water from the city and have to have it trucked in. In some parts of the country, heat is a major issue, and a larger pool requires more heat. No matter where you are, it will require more chemicals, maintenance, etc. But still, if I had two acres, I expect I would get the larger pool.
    Retro Classic Pool built ~1960, remodelled 2018. In ground gunite 16x36, 8.5' feet deep, 8' diving board, 25,000 gallons, polished pebble with glass beads, travertine coping and deck, 420 square foot Pentair cartridge filter, Pentair Intelliflo variable speed pump, Pentair IntelliChlor 60 SWG, Polaris 280 with booster pump, two Pentair Itellibrite colored LED's, autofill
    Jan 2018
    Manalapan
    7
    Re: Pool size
    You bring up good points about chemicals, since I live in central NJ I was only looking into the heat costs.
    Regarding water, I have my own well and water softening system so shouldn't be a huge constraint for me.
    Jun 2017
    Houston, TX
    269
    Re: Pool size
    When it comes to pools, IMO, bigger is always better (to a point). A freeform pool will be smaller than a rectangular pool of the same dimension. I have a 40X24 rectangular pool and I have 2 acres as well. While it IS a big pool, I would have gone for an even larger one. There's really no way to make a pool larger once in goes into the ground.
    Rectangular 24'x40' Salt Water, 4' to 6'. Pentair EasyTouch 8, Screen Logic 2, w/wireless kit. Pentair IntelliFlo VSF Pump, Pentair CCP520 Cartridge Filter, Pentair IC60 Cell, Wet Edge Northshore Tahoe finish. ~28,000 gallons. TF-100 Test Kit. Completed: Dec 2017 Build Thread
    riley00dog's Avatar
    Nov 2017
    Brisbane, Qld, Australia
    2,185
    Re: Pool size
    I'd go bigger for sure.
    3.2 x 6m | inground concrete | ~27,000 litre | 1.2 - 1.8m | salt and pepper mini pebble | SWCG Atral eq35| Viron xt 1.5 HP VS pump | Astral CA280 sand filter | DB3 robot | 2 x LED lights | travertine coping and paving | ceramic waterline tile |
    bmoreswim's Avatar
    Jul 2012
    Central MD
    4,225
    Pool size
    I agree on larger in this case. Our pool is also 18x38 (684 sf) but is rectangular and does not feel small. I would have gone several more feet in length though if the space allowed, to allow for a larger diving well or maybe 9í vs 8.5í. We are on 1 acre.
    Extra surface area would increase heating costs some.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    35,016
    Re: Pool size
    You can help us help you.....................use something like water hoses or a bright rope to lay out the pool where you are thinking of putting it. Get up high (ladder or second story window) to take a pic. That will really show us what you are working with.
    It will also be helpful to know what extra features you will be adding so we will know how they impact the use of the pool.
    Kim
    domct203's Avatar
    Jun 2015
    CT
    3,959
    Re: Pool size
    I donít think Iíve ever seen someone post their regret of getting a bigger pool. Most regret choosing smaller.
    I would go for the biggest you can comfortably fit & afford.
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Esloser's Avatar
    Jun 2016
    Millville, NJ
    511
    Re: Pool size
    What helped me was measuring it out using rooms in my home. It gave me a better idea of the true size of the pool. I originally specíd out 22 x 50 and it looked tiny using cones in the yard. But when I measured out 18 1/2 by 42 using rooms in the house, I got a good idea of how big it was going to be.
    36,000 Gallon Inground (IG) Gunite Pool with Spa and 12" tanning ledge | White Plaster | Cartridge Filter | Hayward Single Speed Pump (x2) | 400k BTU Hayward Heater | Hayward ProLogic Automation | Taylor K2006 Test Kit | In-pool Cleaner | August / September 2016 Build Date | Build Thread
    PoolGate's Avatar
    Jun 2017
    Damascus, MD
    2,374
    Re: Pool size
    The free-form pool in my sigline pics is roughly 42x22 for size reference. We are SOOOO happy we increased the size the day of the dig from 38x18.
    29k Gallon Free Form Gunite Pool, 3 floor returns, 2 wall returns, 1 vacuum pressure port, 2 skimmers, Main drain, Jandy 2.7HP VSP, Jandy JXI400N Gas Heater, Jandy CV340 Cartridge Filter, FusionSoft 1400 SWG, 2 Watercolors LED, iAqualink with PDA, Sheer Waterfall, Rock Waterfall, 9' Deep End w/Diving Board, SunDeck, Polaris 9650iQ, TF-100 - Pool Build - 2017 - Google Photos
    Jan 2018
    Manalapan
    7
    Re: Pool size
    Thanks everyone for your input, looks like the unanimous recommendation is to go for a bigger pool. Attached are pics of my yard and a sketch of my lower level patio & pool20180210_123243.jpg20180210_122533.jpg pool & patio - large pool.jpg
    1 pic from the upper patio, second one from my bedroom
    Saturn94's Avatar
    Mar 2015
    Virginia
    583
    Re: Pool size
    Quote Originally Posted by domct203 View Post
    I don’t think I’ve ever seen someone post their regret of getting a bigger pool. Most regret choosing smaller.
    Agreed!!!
    20k IG vinyl liner/Aqua Rite SWCG, T-15 cell/Hayward Pro Grid 6020 DE filter/Polaris 280 w/booster pump/Hayward Superpump 1 hp/city water/Taylor test kits/pool installed March 2004
    Jul 2012
    Tallahassee, FL
    35,016
    Re: Pool size
    Nice design! I would go with the bigger size for sure. I would also push the decking on the back side out some to help keep lawn stuff from getting into the pool when you mow.
    What state are you in?
    Kim
    Teald024's Avatar
    Aug 2016
    Lyme, NH, formerly Columbus, Ohio
    1,488
    Re: Pool size
    Quote Originally Posted by Avgjoenj View Post
    I don't think a 36x18 is small at all. But, if you have the room and want to spend the extra $, then go for it.
    Jan 2018
    Manalapan
    7
    Re: Pool size
    Yes it is a good suggestion and i actually used that technique when I was trying to figure out the size of the patio. One caveat I have run into with this approach is that anything outdoors appears to be lot smaller given that your line of sight is either from your 2nd floor or from far end of the yard, neighbors house etc .
    Jan 2018
    Manalapan
    7
    Re: Pool size
    Quote Originally Posted by [URL="https://www.troublefreepool.com/members/120737-Esloser"
    Esloser[/URL];120737]
    Quote Originally Posted by kimkats View Post
    Kim
    Central NJ, Freehold / Manalapan to be precise.
    Esloser's Avatar
    Jun 2016
    Millville, NJ
    511
    Re: Pool size
    I measured mine out inside my house to give myself a better concept of the size. Measuring it out outside and placing cones appeared a lot smaller.
    Jan 2018
    Manalapan
    7
    Re: Pool size
    Quote Originally Posted by Teald024 View Post
    I have the room as the pics indicate, regrading spending the extra 2K as most of us I dont want to, but I think my engineer was saying the larger pool would look as if its belongs. He also mentioned given that I have a large patio around it, I should be fine.
    I am hesitantly leaning towards a larger pool ..
    For the pool spec, - SWG, vinyl pool with concrete walls, 1.5 HP single speed pump, gas heater
    For a 36X18 pool, what are the avg maintenance costs if one does it by themselves? Anyone know how much additional would be my maintenance for the larger pool?
    PoolGate's Avatar
    Jun 2017
    Damascus, MD
    2,374
    Re: Pool size
    Maintenance costs are minimal with saltwater pools. As long as you keep your levels correctly you can get away with a couple of hundred/season or less in chemicals. Also it costs me $300 to have the pool professionally closed in the winter. To go a little larger is a negligible amount of additional seasonal costs.
    For your size pool I think you need a 3hp variable speed pump. Single speed and variable speed are frequently the same net price due to utility rebates on variable speed pumps ($400 for me). Any water features? Are you going to heat it? I would also price out gunite/plaster pools. Are you getting automation?
  20. Back To Top    #20
    Teald024's Avatar
    Aug 2016
    1,488
    Re: Pool size
    I am hesitantly leaning towards a larger pool .. (42'x2'0 vs 36'x18')
    I'd guess around 15-20% bigger pool depending on actual shape/ volume. You would pay more to heat it, additional chemical usage as needed, electrical for SWG. pump run time to make the chlorine. All would go up by that ratio.
