Just when I think I have everything figured out after taking care of our pool/spa for the last 8 years, I find something new. This summer I started noticing some dampness in the soil near the equipment that I haven't noticed before. I start digging and find 1" PVC with a threaded end fitting, covered with decaying duct tape. It is filled with rocks/dirt naturally, and the seepage was intermittent over the summer. Recently I decided to figure out where it goes (if anywhere), so I hook up a hose and find that it is emptying into the spa. The outlet in the spa is at the level of the seat. I never knew what it was really there for, guessing it had some connection to the venturi vent system.
After I flushed it out, water was then steadily flowing from the spa. I capped it off any it is completely dry now. Attached are pictures of the equipment and spa. The pipe in question is circled in red.
What is the purpose of this line? Should I just leave it capped, or what do I connect it to for what was originally intended?
Thanks.
Thanks.
