I have a 1.5 HP main pump which was replaced 19 months ago and it is already failing. The pump is labeled for 1 phase power but there are two switches on the breaker panel to control the pump. Is it possible I have 2p power and they installed a 1p motor, or would that have fried instantly and not 19 months later? Here is a picture of my panel, the left single switch is for the vacuum the 2 on the right are tied together and is for the main pump (which is odd since the left timer is for the main motor and the right timer is my vacuum motor). They are all 20A.
Thanks!
EDIT: no idea why the picture rotated 90 degrees to the right, it looks correct on my computer. BTW, I know the timer on the right isn't doing anything. My boost pump is dead as well so I just removed the on/off switches.
Thanks!
