Just an update on my newbie TFP method progress. After a partial drain and refill, receipt of my TF-100 test kit, cheap bleach, muriatic acid and supplies, I couldn't be happier. Despite being in Northern Virginia (first snow tonight), I keep the pool open and modestly heated late. Getting ready to close in the first 2 weeks of January (we like the hot tub on NYE!). Algae blooms are gone and the numbers are getting there.
Dec 4 test after partial drain/fill:
FC 1
CC 0.5
pH 7.8
TA 120
CYA 60
CH 200
Added 64 oz 20 Baume acid and 121 oz of 8.25% bleach. Let it sit for a few days and then tested again.
Dec 8 test
FC 0.5
CC 0.5
pH 7.5
TA 120
CYA 50 (real close to dead center between 50/60, but took my best guess without extrapolating)
CH 200
Will test again in a couple of days to see if things are leveling off now that I've solved the CYA problem (was well over 100 using pucks and strips).
Well on my way to my first SLAM before closing. Water temp maintained ~64 F with gas heater.
Any observations or thoughts for this home-titrating fool?
FC 1
CC 0.5
pH 7.8
TA 120
CYA 60
CH 200
Dec 8 test
FC 0.5
CC 0.5
pH 7.5
TA 120
CH 200
