my spa is flashing the FLO code. pumps all seem to be working fine; including the waterfall when main pumps are off. Temp is set at 100 and seems to get stuck around 99. Filter is 2 years old but spa is not regularly (maybe 1x/week) used but is maintained. i clean the filter regularly. I removed the filter and ran the pumps and FLO code still flashed. I am not comfortable with electronics so really don't want to remove the electrical cover to play around in there. anything additional i can do before calling the tech? I am due to drain it in December (generally every 4-6 months depending on usage) should I drain and refill an see if that helps? crank the heat to 104 and see if it holds at 104?
thanks
thanks
